JD 2010 Voltage Regulator
Rick
05-15-2002 12:05:00
I have a 1964 JD 2010 Gas. I need to get to the voltage regulator to have it tested with the generator and I am wondering what is the best way to get at it.
Every other tractor I have seen usually has it mounted on the generator or at least nearby on the block somewhere. Near as I can tell from peering through the slot for the gear shift lever, it is under the console, right under the fuel gauge...is this correct?
If so, what is the best way to get at the thing? I have the hood off and see an number of bolts for unfastening the cowl or whatever the covering of the console is...what is the best way to do it....between the steering wheel/throttle, gear shift and hydraulics on the console I don't want to have to disassemble anything that isn't necessary!!!
I am doing this because the generator light is on and the tractor will only run for a few minutes before dying. The generator tests out OK but they want to test it with the regulator to see if thats it. Does this sound like the right path to troubleshoot this?
Thanks!
Rick
Rodney A. Johnson
05-16-2002 07:13:53
 Re: JD 2010 Voltage Regulator in reply to Rick, 05-15-2002 12:05:00
1964? It was my understanding that the 10 series was '61, '62, and '63 with the exception of the 2510.
JD60
05-15-2002 18:14:26
For kicks...have you tried running it with a battery charger on???...does it still stall out??
Steve in Tennessee
05-15-2002 19:31:34
 Re: Re: JD 2010 Voltage Regulator in reply to JD60, 05-15-2002 18:14:26
Have you considered changing it over to an alternator with internal regulator? Unless you want to keep it factory original, the alternator sure is a lot better. Just my humble opinion.
