John Deere A 3 pt lift
Garry
05-15-2002 06:49:44
I have a 1949 JD model A with a 3 pt lift. The lift looks like factory 3 pt, but i was informed JD did not have a factory 3 pt for the A's. There is a label on the seat of the tractor with the word powertrol. Is this the same as a 3 pt or something different?
Dave K
05-15-2002 08:31:29
 Re: John Deere A 3 pt lift in reply to Garry, 05-15-2002 06:49:44
The powertrol is simply the name JD had for the hydraulic lift system on these tractors. Has nothing really to do with the type hitch. As far as I know JD did not make a 3 point for these tractors. There was just a rockshaft to connect two lift arms to and connections for external hydraulic cylinders. This system does not have a lot of lift capacity as it is a very low pressure system compared to todays hydraulics. The relief valve is set at 700 pounds pressure. The system is capable of neutral, slow raise, fast raise, slow drop and fast drop. I have most of the tech data on it as I have a 1948 Model A with the same system but not a 3-point.
Dave
Garry
05-15-2002 08:51:10
 Re: Re: John Deere A 3 pt lift in reply to Dave K, 05-15-2002 08:31:29
Thanks for the info. The lift seems to work good but I did not know that it had the different speeds of lift and drop.
