JD45, series 1 loader
kirk
05-14-2002 16:10:55
I am looking at a JD45, series 1 loader from a JD 40 row crop tractor to put on a JD 40 standard. Does anyone know whether this will fit my JD 40s?
Please let me know. Thank you.
kirk
05-16-2002 07:17:34
 Re: JD45, series 1 loader in reply to kirk, 05-14-2002 16:10:55
Thank you all for your assistance. I have another question. What would be the correct model JD loader for a JD 40 standard or a JD 420 utility tractor?
mike
05-15-2002 19:15:59
I know a guy that bought a 420 utility or maybe a W tractor
off the original owner. When new this tractor was equiped with a #45W loader,which requires the right brackets and valves. I do not recommend this set up and neither will the original owner
as his tractor was broken in half and stills wears the scares of welded block and bell housing. This is a big loader for a such a small tractor. They work far better on the A,late B or 50, 60, 70 and so on type tractors.
In a word, no
05-15-2002 08:38:51
No, it won't fit, won't even come close. No place on a 40S to fit the mounts.
F-I-T
05-14-2002 16:46:52
Kirk:
I have a manual for my 45W Series I loader (the W was the bent-arm style loader that was for wide front ends), and under the tractors it will fit, it reads:
"John Deere "420" and "40" Series Tricycle Type Tractors with dual or single front wheel, or adjustable front axle, and with remote cylinder control valve or special loader control valve equipment."
It doesn't say Standard. If it's a straight arm 45, it might hit the front axle before the bucket gets to the ground. I'm also wondering if there is enough rear axle housing area to accommodate the mounts.
Wish I had more info. Hope this helps.
Frank-in-Tallahassee
70D // 855
Jon
05-17-2002 16:20:24
 Re: Re: JD45, series 1 loader in reply to F-I-T, 05-14-2002 16:46:52
I have a 45W loader with hyd bucket with all brackets to fit a 4o/420/430. also have the brackets and different cylinders to make it fit the moline 2 cyclinders also.Guys never say never when it comes to John Deere.
