Another Model 50 carb question
Guy
05-13-2002 07:15:14
In addition to my post about float adjustment, I wondered if anyone could offer some carb adjustment help? I haven't tried to start it since having it apart. I just need it to start, then I can adjust by ear from there. I have the main (I assume) fuel adjustment on the bottom of the bowl, and the two air screws. I have all three turned out 1 1/4 turns right now. The tractor is a gas model with the standard DLTX-75 carb. I would appreciate any help/guidance. Thanks!
Dan in Pa
05-13-2002 15:18:36
 Re: Another Model 50 carb question in reply to Guy, 05-13-2002 07:15:14
Guy 1 1/4 turns is a good place to start,I set my idle screws by pulling off the plug wire on the opposite cyl I am working on till I get a nice smooth idle,the same with the oter side.I can honestly say I have never had to adjust the metering screw to often, 1 or 2 turns out usually
does it . Hope this helps you.
