JD 50 shifting problems
Geoff
05-12-2002 13:18:20
On my John Deere 50 I cant get the shifting lever to go up into 3, 5, or 6. If you've seen a 50 its the whole left side gears. If anybody has any ideas please tell me.
RLA
05-12-2002 15:03:42
 Re: JD 50 shifting problems in reply to Geoff, 05-12-2002 13:18:20
Geoff, There is a shift fork that changes trans from hi side to low side. This fork is out of line & won't let shifter pass thru? You have a detent ball & spring thats suppose to hold the fork in the correct position. After tractors become worn you need to adjust the fork. However the adjustment is on the rh side under the reduction gear housing. You can loosen the shift quaderant & pick it up just enough to realign the fork, but its a temp. fix? It will happen again. While you have the quarderant lifted you can check the detent ball & spring. Your gonna need a manual & view the pix, study them its simple to see, it isn't smiple to adjust. RLA
