FLAT BELTS
JDEEREHUNTR
05-11-2002 20:30:21
Any ideas on where to buy or who makes flat belts for tractor or stationary engine drive pulleys?
BIG JOHN-contact applied ind tech
05-13-2002 04:04:48
 Re: FLAT BELTS in reply to JDEEREHUNTR, 05-11-2002 20:30:21
Applied has 460 locations, and several belt shops, the midwest rubber shop has anything you can imagine-awesome prices
Bob -Wyo
05-12-2002 20:33:45
JDEEREHUNTER if you are close to Wyo I'll give you what you need, have stacks of all kinds up to 120 footers. Used to have this craze and bought every belt at auctions for some reason. But as others have said they are easy to find.
Let me know if I can help.
Bob-Wyo.
zane
05-12-2002 06:53:31
If you can't find it locally, contact Baell Merchantile Co. in Moultrie, GA. 229-985-5151. Ask for a belting salesman. Not long ago they had plenty of it, including splices.
RossMN
05-11-2002 23:07:46
I have seen round balier belts use on threshing machines before. I don't know the lenghts you can get but you could splice a couple togeter to get more length
allen
05-12-2002 04:11:03
 Re: Re: FLAT BELTS in reply to RossMN, 05-11-2002 23:07:46
any John Deere dealer that sell round balers will or should have stock on baler belting, we have it in a bulk roll and have a lacing for the same, can make up a belt very quickly, i have seen belting at tsc stores in ontario that is different sizes and is not as thick, may have to cut to make a 2" wide belt, the same lacing would work.
G Taylor
05-12-2002 08:59:23
 Re: Re: Re: FLAT BELTS in reply to allen, 05-12-2002 04:11:03
York Belting division of Monarch Mcclaren on 329 Deerhide Cres ph#416-741-9675 in Toronto Ontario has belts and splices in stock for anything from sewing machines to gravel conveyors. Good people to deal with too.
