Hook up on #39 Mower
Handsome Jim
05-11-2002 16:04:11
I rrecently bought a JD #39 mower to do trimming around Mom's Lake and today thought I'd hook it up and try it and ran into a problem. The 3 pt. and PTO hooked up okay but there are two U clamps that go around the draft arms and there is no way possible they are going to fit. The arms are 3" wide and the clamps are at least a 1/2" short. Everything seems to work alright and the bar raises when I raise the 3 pt like it's supposed to. Is it Okay to go ahead and use it like it is, or do I need to make changes? Thanks,HJ.
John
05-12-2002 02:51:17
 Re: Hook up on #39 Mower in reply to Handsome Jim, 05-11-2002 16:04:11
Make up some brackets to fit. Put in extra hole so they can be adjusted vertically. that gives you some better pitch angles for different tractor mountings. Once fine tuned the 39 is a good machine. Beats the heck out of the old #5 which was good too.
