JD 5020 oil leak
Stan
05-10-2002 17:52:09
I recently purchased a JD 5020. It has a lot of power, but now it has developed a oil leak from the transmission it leaks from the clutch inspection plate area. I assume this is a seal. Is this seal easly replced after the tractor is split in to? Any help with my problem will be appreciated.
JD 4000
05-10-2002 19:28:21
 Re: JD 5020 oil leak in reply to Stan, 05-10-2002 17:52:09
my guess will have to be split..
say it may be bit of hard to do it not less you have stands to split it. it will take alot of unhook wires and pipes and bolts..
