Broken Steering Piston on John Deere 4500 4x4
Bob MacDonald
05-08-2002 17:58:09
The steering piston on my three year old 4500 broke after 100 total hours during a tight turning maneuver. Did not hit anything. Is this normal?
John Deere refused warranty, since over two years old. However I see they redesigned the front steering in last few years to eliminate this problem. Dealer also said he has had 10% failures on my design.
Seems like they should be covering this as defective design.
Bob
ed b
05-09-2002 20:01:18
 Re: Broken Steering Piston on John Deere 4500 4x4 in reply to Bob MacDonald, 05-08-2002 17:58:09
i have got 550 hours on my 4500 year and a half old very tuff hours its going in just before warrenty is up and i will definetly have them look at that thanks for the info post back like to see if deere will do something to help you out ed b
mike
05-09-2002 18:13:11
Did Deere refuse or just your dealer? Make sure you talk to the area service rep. in person and call Deere and complain if you can get a phone number. I have worked for various tractor and car dealers before and know how they treat you after the sale . They don't give a darn! But usually the higher ups at a company will do something. Keep posting and maybe someone who still works at Deere will help you or at the very least give you a phone number to call. The squeaky wheel gets the grease.
Russ
05-08-2002 18:05:05
Just recieved a new 4600 and hope ot is the new design. I assume you are talking about the power steering cylinder behind the axle? My father had one break on a JD garden tractor years ago and I remember it as being very flimsey.
Bob MacDonald
05-09-2002 11:54:00
 Re: Re: Broken Steering Piston on John Deere 4500 4x4 in reply to Russ, 05-08-2002 18:05:05
You are correct that the part that broke is the steering rod that comes out of the cylinder located behind the front axle. I looked at the new 4500/4600 at the dealer and it has the a new design with a beefier steering case and rod.
Appears to have been bad design on my three year old tractor. They have appeared to fix problem but not willing to warranty failures of the bad design.
Bob
