John Deere 40T Tires
Howard IA
05-08-2002 17:05:19
Where can I buy tires for this tractor.
No one around here has them.
11.2/10 x 34 on rear and 750/10 on front.
Has a single front wheel.
Thane LaFollette
05-09-2002 09:52:23
 Re: John Deere 40T Tires in reply to Howard IA, 05-08-2002 17:05:19
I put Titan tires on my 40W, 3 years ago. Same size rears you are looking for. Any tractor tire store should be able to help you. I dealt with Kantner's Tire, in Shoemakersville Pa, the largest, closest dealer in my area.
BMeyer
05-09-2002 02:58:03
Check this site..... www.millertire.com
They have what you need and the lugs will be 45 degrees and straight like they were in the 50's when that 40T was new.
G Taylor
05-08-2002 21:43:04
The 11.2x34 is uncommon. Firestone does make a radial with R1-W tread in that size.
Wayne in Tn.
05-08-2002 18:41:07
Howard, any farm tire dealer should be able to get the rears for you. They are available in a Titan brand. I get my local C0-OP to order them for me. As to the fronts, I am not sure about the size you mention. It should have 15 or 16 inch wheels and tire size from 4 to 6:00 These are available anywhere that sells farm tires.
