Help with a 70 Gas flywheel placement
Tom
05-08-2002 14:45:30
I am about to get my 70 home after wintering it at the previous owner's shed. The flywheel is off of it right now and I need to put it back on. If someone could give me advice on what I need to do, I'd sure appreciate it. I have the operator's manual and the parts manual but they are of no help here. As much detail as possible would be appreciated. I am assuming I will need to line up a TDC mark? Thanks in advance for any/all advice.
Tom
Dale W
05-08-2002 22:13:45
 Re: Help with a 70 Gas flywheel placement in reply to Tom, 05-08-2002 14:45:30
I am not sure on the 70, but the lettered tractors have a V mark or a punch mark on the flywheel and the end of the crankshaft. You need to line them up to have correct balance. Check yourshop manual for end play adj of crank. Make sure that you get the bolts tight, and check them once in a while to make sure they stay tight. Hope this gets you going.
