Do B flywheels ever get loose like other 2 cylinder JD's
Bob Weber
05-08-2002 14:20:11
I've seen quite a few postings about flywheels and/or crank splines getting worn and loose, causing knocking sounds, etc. Does this primarily happen on the larger models, or is any 2 cylinder JD prone to this?
jdman(MO)
05-08-2002 16:02:37
 Re: Do B flywheels ever get loose like other 2 cylinder JD's in reply to Bob Weber, 05-08-2002 14:20:11
They sure do, had to replace the one on my 50 B,had been tightned until it was cracked and most of the splines were missing from the flywheel, and it ran. Got a used one, and gave it a liberal coating of JB weld, still holding after 9 years. Russ
