John Deere R removal of Injection Pump
Ben
05-08-2002 14:03:57
The instructions in the shop manual are not real good, has anybody done this and how to do it, The top cover is off, do you have to take the injectors out and get the lines loose, I removed the four bolts in the diagram and it is still wedged in there with the lines, the side drive, and the back pushrods keeping it in a tight bind.
Any info would be appreciated.
Gord
05-08-2002 19:17:51
 Re: John Deere R removal of Injection Pump in reply to Ben, 05-08-2002 14:03:57
Hi Ben, you should take the lines right out and the side drive connecter off (pull hair pins and slide rack sideways so connecter comes out)and then you will have to work it back and forth from side to side,up on one side a little and then the other and so on as it is sitting on dowels and has to come straight up with a good amount of wiggling. Gord
