JD Model 60 flywheel timing marks
Mike C.
05-08-2002 11:34:21
According to the shop manual the flywheel should have TDC stamped in it. Also other marks such as 5 degrees ATDC. Mine doesn't have these marks. The best I could find is 3 dimples, one larger than the others. When I bring it up on the compression stroke and all the values are closed (value cover removed for visual) the larger dimple can be viewed thru the timing window. So has anyone had experience with this type of flywheel? It was suggested by the JD shop that this might be a after market flywheel.
ROOSTER IN TENNESSEE
05-08-2002 19:10:00
 Re: JD Model 60 flywheel timing marks in reply to Mike C., 05-08-2002 11:34:21
Mike My 720 gas had three dimples for TDC for #1. It will also have LHEO that is the valve timing mark. It will also have TDC for #2. I had to take my flywheel cover off and clean my flywheel to find mine. You can paint the number yellow so you can see them better. Hope this helps
Mike C.
05-09-2002 07:37:44
 Re: Re: JD Model 60 flywheel timing marks in reply to ROOSTER IN TENNESSEE, 05-08-2002 19:10:00
I have removed the flywheel cover and cleaned the flywheel and found no stampings at all. Now on the side of the flywheel it has large raised letters indicating the position of Left Hand Exhaust Open. The 3 dimples I refered to before are not close together. They are about 2 - 3" apart. One before the larger dimple and then one after.
G-MAN
05-09-2002 13:47:14
 Re: Re: Re: JD Model 60 flywheel timing marks in reply to Mike C., 05-09-2002 07:37:44
Mike, are the bolts for tightening your flywheel on the inside or outside of the wheel? I don't recall my 60 flywheel having the "LH exhaust open" cast into it. Is it possible that your tractor has a flywheel from an A on it? I don't know if that would even work, but I just don't see anything cast into the flywheel in the pictures in the service manual. If the bolts are on the outside of the flywheel, you probably have the correct one. If not, maybe somebody installed an earlier flywheel. Like I said, I may be way off base here, but that's all I could think of when I read your post. Good luck with your tractor.
