4020 vs 4010 block
jeff
05-07-2002 19:05:42
Can someone help me. I'm trying to overhaul and replace a cracked block on a 4010 diesel. Does a 4020 block work? If so what is different about it? Are there any combine motors that would work?
Paul
05-08-2002 06:39:01
 Re: 4020 vs 4010 block in reply to jeff, 05-07-2002 19:05:42
the 4010-4020 blocks are for the most part interchangable. the 4010 has two bolts on each side on front that bolt to side rail. the 4020 has four. the 4020 block also has a hole for a block heater. I was wishing I had gone to a 4020 block when I went through my 4010.
