52 B (clooney or john T)
39B
05-07-2002 18:42:29
Question on tansmission now. I have a 52 B and 4,5,6 gears someitmes work and sometimes they don't work and sometimes they do. i put in one of these gears and try to go and it does nto work. But last week they all worked perfect. ANy ideas woul be great -thanks for all the help
phil
05-07-2002 19:57:42
 Re: 52 B (clooney or john T) in reply to 39B, 05-07-2002 18:42:29
39B, could it be 3,5,6 rather than 4,5,6? When the trans is in low range, the gears are 1,2,4. When it's in high range the gears are 3,5,6. You should be able to feel the high-low shift when you move the lever thru the gate across the bottom.
Clooney
05-07-2002 19:01:36
39B, you didn't give us much to go on.
~Exactly what happens when you try to go in 4,5,& 6 gear? ~Are you sure the clutch isn't slipping? That usually slips worse in the higher gears.
~It could also be a worn input shaft outer bearing, or overdrive shifter, or bad bearings on the sliding gear shaft, of a variety other problems.
~If it isn't the clutch, you will probably have to pull the trans cover to find the problem.
~Give us all the info you can on EXACTLY what it does or doesn't do & anything else you can think of.....
