Ingnition switch on a 49 B (My Memory is Going)
Scott in MN
05-07-2002 15:35:29
I took out the ignition switch on my 49B last fall with the intention of replacing it. It is a key switch. I have found a replacement now I don't remember which wires go where. (I did write it down but, of course, I lost the sheet of paper) It's a 12 volt system. I think there is one wire that goes to the alternator, one wire to the battery and one wire to the distributor. Thought I would get some imput before I go up and getting running again. Thanks for making up for my crappy memory.
Clooney
05-07-2002 18:45:36
 Re: Ingnition switch on a 49 B (My Memory is Going) in reply to Scott in MN, 05-07-2002 15:35:29
Scott, not sure we can help you unless you furnish a little more info on what type of switch, what wires you have, where they attach on the engine & what kind of alternator.
~Your "B" came with a 6 volt system & a generator, so it has been converted to 12 volt & an alternator added. With the addition of an alternator there was probably wires added to initiate the alternator charging.
~If you can explain what you have, we can probably help you.....
Scott in MN
05-08-2002 11:47:10
 Re: Re: Ingnition switch on a 49 B (My Memory is Going) in reply to Clooney, 05-07-2002 18:45:36
There are two positions on the switch. 2 wires were connected to one side and one on the other. It is a key switch one position is off the other is on. One of the wires runs to the alternator. Another runs to the battery, the third to the coil. If i wire all three of these leads together the tractor will start. Hope this is enough info, if not let me know. Thanks for the help.
Clooney
05-08-2002 12:39:44
 Re: Re: Re: Ingnition switch on a 49 B (My Memory is Going) in reply to Scott in MN, 05-08-2002 11:47:10
Scott, an easy one after your thorough explanation.
~The [battery] power hooks to one terminal of the switch [either side] & the [coil] + [alternator] hook to the other terminal.
