Deere 40-S
Bill Childress
10-17-2003 04:45:12
I am having a dickens of a time getting her started. Doesn't have any spark at either plug. Have replaced the condenser and the ignition switch, and the coil is ok. The points, rotor and cap all look ok. The voltage regulator has some burning on the inside, but would that prevent spark at the plugs? Help!
Clooney
10-17-2003 07:12:15
 Re: Deere 40-S in reply to Bill Childress, 10-17-2003 04:45:12
Bill, start with a voltage [or test light] test at the ignition switch side terminal of the coil..
~If you don't have close to battery power there with the ignition switch turned on you either have a blown [or corroded] dash fuse, open wire, poor connection, or for some other reason aren't getting battery power to the coil.
~If you have good [close to] full battery power at the coil then your problem is in the coil, distributor, or points..
~Move the voltmeter [or test light] to the distributor side of the coil & crank the engine.. If the light flashes on & off while cranking your points are working & the problem lies elsewhere.
~If the light doesn�t flash suspect corroded or oxidized points [a common problem].
~If the light flashes on & off but still no spark MAKE SURE your distributor is grounded to engine [another common problem on the 40]..
~If the above checks out good then test for a spark directly at the coil tower by holding the coil wire within about 1/8�-3/16� of the engine block & cranking the engine. If you have spark there & not at the spark plugs your problem lies from the cap to the plugs.
~You might try new spark plugs first as that is a leading cause of a problem like yours. If that doesn�t help you will have to try replacing the cap, or rotor, or plug wires..
~The best approach to finding your problem is working through your ignition system using the above, then ISOLATE your problem to one of the mentioned areas then once isolated it will be easy to find & repair�
~It helps to print out the above & take it to the tractor while working on it� [email protected]
DiggerLarry
10-17-2003 06:46:00
Or maybe the coil wire but I would check the dash fuse first.
Tom-nj
10-17-2003 05:11:26
This happened to me on my 40S and it was the fuse behind the dash panel.You should be able to get at it when you remove the battery cover.
Tom
Dan
10-17-2003 05:07:20
if it's like the 420, there is a fuse on the dash panel, check that before ya spend a lot of time replacing other things.
Henry J
10-17-2003 05:00:42
Bill
Run a jumper wire from the battery cable on the starter terminal (after you have verified that you have voltage there, which it sounds like it cranks ok) to the battery side of the coil. If it fires then you know which way to look for the voltage problem. You could also hook a voltmeter on the bat side of the coil with the switch on to see if you are getting juice to the coil to begin with. Good Luck
