John Deere M, Still not running
vic
05-06-2002 23:23:53
I'm beginning to think this engine may have jumped time. I took the oil pan off, and checked around. Best I can tell, it appears ok. I turned the engine over a few times. I also took the valve cover off, and checked that, there again, it appears ok. I put it back together, put the spark plugs in it, now it has NO COMPRESSION. What's the problem? I put oil in the cylinders, it made no difference. Without tearing it apart, I have no clue what else to do.
Clooney
05-07-2002 03:18:49
 Re: John Deere M, Still not running in reply to vic, 05-06-2002 23:23:53
Vic, those things usually don't just jump time. If it did you have more problems than compression.
~A good place to start is to pull the rocker assembly so all the valves are closed then make a spark plug adapter from a gutted old spark plug & air hose fitting then put about 80 psi of air pressure in each cylinder. That will show where the problem is by where the air comes out.
~My guess is you have burnt valves.
~If the cylinders are holding a reasonable amount of air pressure you can them move on to cam gear problems.
~You can check the valve timing without disassembly by using the mark on the flywheel & valve position.
vic
05-07-2002 03:34:03
 Re: Re: John Deere M, Still not running in reply to Clooney, 05-07-2002 03:18:49
thanks clooney, i'll try that. just wondering, do you think it could be a head gasket?
Clooney
05-07-2002 07:02:09
 Re: Re: Re: John Deere M, Still not running in reply to vic, 05-07-2002 03:34:03
Vic, a blown head gasket is possible. You will know that when you put the air pressure in as it will come out or the other spark plug hole. If the gasket blew other than between the cylinders you would only loose compression on one cylinder.
