4320 hydraulics
steve macomber
05-05-2002 18:15:30
: I recently purchased a 4320. However I can't seem to get the hoses to snap in the remote hydraulic hook ups. Does this tractor use a different style connector than the rest of my tractors/ equipment???
: Thanks for your help!!
: Steve
Doofus
05-05-2002 20:36:26
 Re: 4320 hydraulics in reply to steve macomber, 05-05-2002 18:15:30
You will probably need the John Deere male ends to plug into the selective control valve, or Its possible that she could have converted to ISO fittings so the old Pioneer ends would work then. If your old Pioneer ends dont work try JD ends. Make sure that he lock levers point straight back to plug in then turn them 90 degrees to lock the connection.
RHA
05-05-2002 19:57:48
There are a couple of possibilities. It may have been converted to ISO Universal inserts. The old style tapered tips won't work. Sometimes if the hyd outlets haven't been used in a while they can seize up with dirt or rust and you have to drive them back and forth to loosen everything up.
