DLTX carb
JDave
12-12-2003 14:32:04
I have two brass carb DLTX 7---DLTX 8 look to be the same size rebuilding them now -- the 7 came off my 38 A --- the 8 came out of a bucket-- I have a 36 B ---want to put them on ---put the 8 on the A and the 7 on the B ???
Duane Larson
12-12-2003 15:53:50
 Re: DLTX carb in reply to JDave, 12-12-2003 14:32:04
DaveJ,
Well, you don't have exactly the correct carb for either. The DLTX8 was used on A's up to s/n 424850, at which time it was replaced by the DLTX18, which has a cast-iron body and is the later version of the 8. If you are going to use it, put it on the A.
The DLTX7 is for a 1932-33 GPWT over-top steer, and you could sell that and probably buy several of most any carb you want. Pretty hard to find. However, sometimes those stamped casting numbers are hard to read. Look hard - if it is a DLTX9 it came on an early AR/AO up to 252405. More of those around, but still a good carb to own.
Your 1936 B came with a cast-iron DLTX10 carb, and has a smaller throat than either the 8 or 7. While it will bolt up, it is not properly sized (in terms of air/fuel flow) for the B.
JDave
12-12-2003 17:34:53
 Re: Re: DLTX carb in reply to Duane Larson, 12-12-2003 15:53:50
The DLTX7 is stamped on top of the carb between the adjustment needles DLT8 is cast in the center post of the carb with the bowl off The old mechanic that gave me the bucket full of mags and 3 of these brass carbs had a GPWT don't remember about the top steer this was 25 years ago
JDave
12-12-2003 18:21:01
 Re: Re: Re: DLTX carb in reply to JDave, 12-12-2003 17:34:53
The DLTX7 has numbers stamped on the flange intake end 2047872 does that mean anything?
Duane Larson
12-12-2003 19:34:05
 Re: Re: Re: Re: DLTX carb in reply to JDave, 12-12-2003 18:21:01
JDave,
MS did add stamped serial numbers in that location at various times during production. Some service dealers also used to stamp carbs and mags following their work. The digits don't send a secret message to me anyway.
It sounds like you have the real thing. Some OT Steer guy would like to have that, I'll bet.
