Head Gasket Installation on JD 60
Chas036
05-05-2002 11:23:34
I am ready to install the head gasket on mi JD 60 but reading in the manual it calls for the smooth side toward the block. Niether side of the gasket is smoother than the other, which side do I use towards the block?
Also it calls for the gasket to be soaked in oil for 5 seconds. What is the purpose of this?
It also calls for shalac to be used on the surfaces, What kind of shalac and where do you get it?
Leon R
05-05-2002 18:10:15
 Re: Head Gasket Installation on JD 60 in reply to Chas036, 05-05-2002 11:23:34
I just did mine and the gasket that came off had the stamped lettering facing the crankcase. I suspect that the oil helps the gasket move as you torque the head and it compresses. I don't know of any other shellac other than regular wood finishing shellac and that is what I used. I assume it gives gaskets better adhesion and sealing. If I am wrong somebody is sure to jump in and comment. Anyway that's what I did!!
Mike F
05-05-2002 19:12:39
 Re: Re: Head Gasket Installation on JD 60 in reply to Leon R, 05-05-2002 18:10:15
On my 60 I placed the gasket with the bore rings facing the head, the other side won't have the ring outline and put it toward the block, I use the K-W copper spray on all my metal gaskets and it has worked well, 2to3 coats per side and let it dry about a minute between coats, don't spray it on real thick , just light coats and install soon after the last coat, I think my 60 will be done soon and I'll post the pics.
