JD G; wico x mag ?
mike
05-05-2002 10:04:11
Tractor ran fine 3 weeks ago. Won't pop this am. Weak spark (very weak). New plugs, no better. Rebuilt mag w/ new wires last spring. Pulled cap, no moisture in it and points are opening closing. Condenser problem?? Any suggestions appreciated
John T
05-05-2002 17:47:56
 Re: JD G; wico x mag ? in reply to mike, 05-05-2002 10:04:11
Mike, I dotn see all that many bad condensors, more often its pitted or carboned up or oxidized over points or a weak or broke srping like clooney mentioned, so try a point cleaning and gap check and with the plugs out roll her over and listen to how loud and sharp she snaps when she fires and let us know. Ol John T in Indiana
Clooney
05-05-2002 10:27:02
Mike , does the mag impulse snap when turning the flywheel? If not suspect a broken impulse spring.
~If the impulse snaps, look for oxidized points {clean the points or repalce them} .015 gap.
~It isn't out of the question to have a failed condeser but I would put that way down towards the bottom of the list....
