3020 loader
Woodman
05-05-2002 05:51:38
Can anyone suggest a good loader for a 3020? new or used.Any idea on prices? Thanks
thurlow
05-05-2002 07:36:25
 Re: 3020 loader in reply to Woodman, 05-05-2002 05:51:38
The 46 is a lighter built loader than the 48 and 58 series. However, it is a quick-attach (on or off in 5 min). I've got 2 of 'em; they'll handle pretty much anything your front-end will. Prices probably in the $500 range, depending on your location.
Brokenwrench
05-05-2002 06:23:16
A JD 148 is a loader that was designed to be used on the 3020 & 4020 tractors. A good straight unwelded 148 with row crop brackets and 5' bucket will be around $2000. Beware of some of the cheaper aftermarket loaders because the sub-frames are not as strong and I have seen broken tractor frames and srtipped out engine block to frame bosses because of sub-frame flex. I use grade 8 hardware and locking nuts when I mount a loader. JMHO
BW
05-05-2002 06:21:48
We used a jd 148 loader on our 3020 it was a good match.
Woodman
05-05-2002 17:34:57
 Re: Re: 3020 loader in reply to BW, 05-05-2002 06:21:48
Thanks for your advice. I will look for A 148 loader. Any suggestions?
