49 B, Transmission
Tom
05-03-2002 19:34:03
The oil has been overfull. I think its coming from the Hyd. unit as this has been low. Any ideas on what to replace to correct this?
Mike F
05-03-2002 19:39:11
 Re: 49 B, Transmission in reply to Tom, 05-03-2002 19:34:03
this happened to my A one time. the gasket in the lower end by the pto, it gets bad and will let the hydro oil get into the tranny oil. its not a huge fix, but you may want to replace all the gaskets and seals all over down there while it is apart, also might consider pulling the whole main cover and putting a new leather seal on the pump piston while doing it.
Tom
05-03-2002 20:03:49
 Re: Re: 49 B, Transmission in reply to Mike F, 05-03-2002 19:39:11
Thanks. Is it a big job to replace the leathers. The hyd does seem a little weak.
