JD 290 Corn Planter....
Larry
05-03-2002 06:19:01
Would anyone know how to set the population on on of these units. I'd like to plant corn this weekend and don't have time to get an owners manual. I'll get one later.
David B
05-03-2002 14:20:00
 Re: JD 290 Corn Planter.... in reply to Larry, 05-03-2002 06:19:01
If it is like mine, you have two sprocket to pick from, a large 13 tooth and a small 6 tooth plus the 3 different speeds on the gear box. with 16 cell plates using the large sprocket it will space the kernal 7.2" in #4, 9.7" in #3, and 14.5" in #2 and then by going to the small 6 tooth sprocket it will space the kernal 15.7" in #4, 20.9" in #3 and 31.4" in #2. If you use 24 cell seed plates the distance of the above figures wiil be about .66 of that spacing. The population with 16 cell will only be 22,923 when running the planter at 7.2" spacing on 38" rows. I plant a little higher population than that. You can buy an operators manual from your JD dealer and seed charts are in most seed corn "pocket books" as well as in the manual. David B
Larry
05-03-2002 19:00:50
 Re: Re: JD 290 Corn Planter.... in reply to David B, 05-03-2002 14:20:00
Thanks for the reply. I'm going to put this planter on the back burner until next year. It was such a nice day today that I went ahead and planted my corn with the 1240.
JD 4000
05-03-2002 12:57:35
There is a 290 owners manual planter book on E bay
look up deere planter.
Larry
05-03-2002 19:02:20
 Re: Re: JD 290 Corn Planter.... in reply to JD 4000, 05-03-2002 12:57:35
Thanks. I'll go take a look.
