Jd starter
david
05-02-2002 18:40:18
On a jd 50, there is a small wire terminal on the starter switch that is only hot when the starter is engaged.The wire goes directly to the coil.Is this to give a full 12 volts to the coil for easier starting. Older models ( 6 volt ) dont have this. Please explain. Thanks. David
Clooney
05-02-2002 19:11:12
 Re: jd starter in reply to david, 05-02-2002 18:40:18
David, it's called "by-pass" starting. ~Some, but not all 12 volt ignition systems use a 6 volt coil with a resistor between the ignition switch & coil to lower the 12-14 volts in the system to 6-8 volts to power the coil. The main reason for using a 6 volt coil on a 12 volt system is to allow the coil to receive 11 or so volts during cranking to produce a hotter spark for easier & faster starts. ~On your 50 there is a second contact on the starter switch that hooks to the coil [power side] & by-passes the resistor during cranking to feed 11 or so volts to the 6 volt coil during cranking, once the starter switch is opened & the starter quits, the coil is powered through the resistor & the coil receives 6-8 volts for continuous running.
~On point equipped 12 volt ignition systems the points can only carry a reasonable amount of current without burning & a 6 volt coil has very low resistance that passes more current than a set of points can safely handle, so the resistor is needed. ~On a 6 volt system with a 6 volt coil, the coil has the same low resistance but the initial voltage is lower so the current to the points is under the point damage threshold. The problem with a 6 volt system is the coil only receives about 5 volts during cranking & that is barely adequate to produce a decent spark. Any extra resistance in a 6 volt system due to old wiring, poor contact of connections, oxidation or low battery leaves the coil with even less voltage during cranking & sometimes a no-start condition due to poor spark. You can see how a 6 volt coil operating at 11 volts was quite a help in the starting department.....
