Engine clutch 70 John Deere gasoline
Tom Kelley
05-02-2002 09:59:18
The clutch started smoking and slipping on my model 70 last winter while I was pushing snow. I replaced the disks about a hundred hours ago and was suprised that they were slipping already. When I disassembled the clutch all the replaced disks looked to be in pretty good condition, yet there were pieces of clutch material inside the pulley.
When I finally checked the owners manual I discovered that I had neglected to replace the pad behind the drive disk. Do you guys think that this could be the problem?
Since replacing the disks the clutch does not fully disengage when the lever is pulled all the way back. When the lever is just pulled back enough to bring it out of the fully engaged position, it seems to function well. But when the lever is pulled back hard, as in an emergency stop to avoid running over a fencepost, the tractor keeps on going. I only throw this in because it has bothered me for some time and I thought it might be a clue.
Anyway, I can't remove the drive disk from the crankshaft. I was unable to find a puller large enough to accomodate the 1/2" bolts, so I fashioned one myself from angle iron. After a month of soaking penetrating oil, tapping with a hammer and alternately tightening and loosening the puller, not so much as a budge.
Any suggestions as to getting this thing off?
Also the book suggests aligning the timing marks on the disk and crankshaft during reassembly. Mine are already off a couple of teeth. Do I replace them that way or follow the instructions?
Thanks in advance for your help.
Jack
05-02-2002 11:58:04
 Re: engine clutch 70 John Deere gasoline in reply to Tom Kelley, 05-02-2002 09:59:18
If you pull the lever back hard it will try to pull,mine did too.Tighten up your pulley brake.I broke my drive disc trying to get it off and ended up cutting it with a torch.What a mess.I had to buy a new drive disc from Denglers.Wasn't cheap,190.00 bucks.Maybe someone will have a good idea on getting it off.Good luck.Later Jack(TN).
JD70Jim
05-02-2002 12:53:03
 Re: Re: engine clutch 70 John Deere gasoline in reply to Jack, 05-02-2002 11:58:04
Try the instructions on page 92 of OM-R2035 which is the Operator's Manual for the 70 series tractor. It says to use two, 1/2 inch machine bolts, which are inserted into the two holes. In the same manner that you use the jacking bolts when adjusting the wheel spacing, you alternately tighten these two bolts so that they drive the driving disc apart from the housing. WD-40 should be completely unnecessary. Also, when reinstalling the clutch driving discs and facings, align them with the "v" marks. Someone has previously installed them incorrectly. Good luck.
G Taylor
05-03-2002 09:30:13
 Re: Re: Re: engine clutch 70 John Deere gasoline in reply to JD70Jim, 05-02-2002 12:53:03
It's possible this tractor had loose driving disk/crank splines. Possibly some hack tinker has JB welded the splines to eliminate the play making removal tough?
