Clooney , carb or air
Don
05-02-2002 03:32:48
Have a 60 JD with a DTLX 81 carb. Starts on the first roll, idles great, runs wide open great, but wants to shutter and like a half miss at mid. throttle, have run carb cleaner through it with no improvement. Would you suppect dirt or should I go to the air filter. before I pull carb will have to get new manifold gaskets.
Clooney
05-02-2002 03:56:41
 Re: Clooney , carb or air in reply to Don, 05-02-2002 03:32:48
Don, does running with the choke 1/2 on or so improve the mid throttle runability? If so suspect a plugged 2nd or 3rd idle orifice.
~If the choke doesn't help, the problem is probably not in the carb & could be ignition (mid throttle has high combustion pressures & takes a good healthy spark to fire there).
~Also look at the heat valve in the exhaust manifold to see if it is set to EXACTLY hot or cold & not in between (if not lined up exactly you get exhaust back pressure), that is usually both a mid range & WOT problem but it wouldn't hurt to check it.
~Eliminate the above & if it still acts up, or you can't isolate the problem, post back for more ideas..... ....
