6V. to 12V.
Don Hatton
05-02-2002 01:47:41
Hello, JD M tractor has 12 volt system, one wire alternator, would like to use orginal switch to run and lights. What is the correct way to wire up switch?
Clooney
05-02-2002 02:38:34
 Re: 6V. to 12V. in reply to Don Hatton, 05-02-2002 01:47:41
Don, just run a wire from the [lights] terminal on the light switch to the lights & make sure the [battery] terminal on the light switch has 12 volts to it (usually from the ammeter non battery side.
~You will have to install 12-14 volt lights, or use resistors, or wire the lights is series.(if wired in series, both lights will go out when only one burns out)
~If you need more information, or want to wire the lights in series so you can use the existing 6 volt bulbs, post back or E-Mail & I will make you a simple wire diagram..
