Busted block
A Man
05-01-2002 21:26:27
i started one of my A and discovered it had a cracked block on the very bottom is there an easy way to fix this or do i have to replace it any ideals would be nice since pulling season is near
Gerald Michaels
05-02-2002 18:45:53
 Re: busted block in reply to A Man, 05-01-2002 21:26:27
Hi, Get some P C 7 and clean the block surface real good,put pc7 on, let dry 24 hrs. refill with h2o and you are back in working order. Done that to an A I had,lasted for years even with anti-freeze in it. Have a good day
A Man
05-02-2002 19:16:37
 Re: Re: busted block in reply to Gerald Michaels, 05-02-2002 18:45:53
what is PC7 and where do you get it
Gerald Michaels
05-02-2002 19:36:52
 Re: Re: Re: busted block in reply to A Man, 05-02-2002 19:16:37
Hi, It's an epoxy type of metal glue,something like bondo, it bonds anything to everything. Any auto parts store has it. It comes in two tubes,you mix equal parts of black and white together and put it on. Have a good day.
