JD disc
wade
05-01-2002 09:36:54
I am looking into buying this JD disc, can anyone tell me what it is worth and what model it is. It is about 13.5 feet, tandem wheels, 24 inch fluted coulters. and 1 shank cultivator in very center of disc in between front and rear gangs. blades in front are new and back gang are fairly good. thanks.
Mike Aylward
05-02-2002 15:21:12
 Re: JD disc in reply to wade, 05-01-2002 09:36:54
Wade, with 24" blades I would guess your disk is a TW, TWA, 1630 or 1640 disk. The TW and TWA are pretty much the same disk with the exception of the scrapers. The 1630 and 1640 are updates of the TWA series and the 40 has heavier spools where the bearings are. Otherwise they are very similar. If this is what you have you are talking much more money than a smaller tandem disk, plus you will need some horses to pull it. Hope this helps. Mike
DaveH
05-02-2002 09:41:57
Wade,
Deere made quite a number of different disks. I could only guess as to what disk you are looking at. If you could post a picture or email me some I might be able to help you out on the model. I have accumulated a binder full of Deere disk parts catalogs that I could look through.
As far as price I'll tell you what I gave for mine. It is a 8 1/2 foot RWA built prior to 1969. It had brand new blades on the front and nearly new on the rear. Came with an Allis Chalmers hydraulic cylinder. I paid $300 for it. I put another $100 in it to replace grease zerks, l wheel bearing and some scrapers. Now with the exception of paint it's in nearly perfect condition.
The one shank cultivator that you describe was called a middle breaker by Deere. It was used to knock down the ridge of soil in the middle that a disk leaves. Some day I hope to find one to add to my disk.
DaveH
