850 Engine Locked Up Won't Turn Over
Kent Szabo
05-01-2002 06:18:10
My wife and a couple of her girl friends were hooking up the post hole digger, and they changed all the hydraulic lines. Then engine would only turn over slowly and not start. I tried when I got home and engine made two revs and stopped. Charged battery (40 months old JD), pulled and checked starter, cleaned all ok with that. Replaced starter. Put in new Optima 800 amp battery. Tried next morning engine made two revs and stopped. When you engage starter fan turns 1/4 inch at a time. Something appears locked, like maybe the hydraulic pump. If so how do you free it.
mike
05-02-2002 19:44:13
 Re: 850 Engine Locked Up Won't Turn Over in reply to Kent Szabo, 05-01-2002 06:18:10
If you suspect the hyd. pump you could unbolt it from the engine I had to do one for a neighbor
and it was easy to unbolt. If you did have a dead end on the hyd. circuit it would probably shear the key off in the pump though as that is what happened to his. You might have coolant in a cylinder from a blown head gasket check level at radiator and leave cap off when cranking engine to look for bubbles. Did they by chance fill it up with GAS it could screw it up. But my neibor did this too and he drained and refilled with diesel and bleed system and his still works . He must be lucky.
