John Deere 50 3point
HANK
05-01-2002 04:49:16
I looked at a pretty good 50 that is running well
but the 3 point wont stay up:
It lifts well, but the moment the lever is released it goes down. is this a major fix, or a simple fix?
Clooney
05-01-2002 15:45:26
 Re: John Deere 50 3point in reply to HANK, 05-01-2002 04:49:16
HANK, while anything is possible, a sinking rockshaft [3-point] is usually no big deal & the usual cause is a leaking "0" ring on the rockshaft piston. ~If the power-trol is full of oil (and if the guy selling the tractor didn't just fill it to fool you) the cylinder to housing gasket is probably OK & the problem is more than likely a piston "0" ring or valve body gasket [the valve body has to come off to replace the "0" ring anyway so that shouldn't be a big repair].
~If the power-trol is low or losing fluid, you could possibly have a blown cylinder to housing gasket, & as Frank said the rear housing will have to come off for that repair. ~You might want to cycle the 3-point up & let it drift down on it's own {leave the lever in the up position} a number of times to see if the power-trol oil level is staying up, if so the repair should be relatively easy.
~If you decide to buy the tractor, post back & we will talk you through the troubleshooting & repair of the sinking 3-point..... ..... ...
F-I-T
05-01-2002 06:01:30
Hank:
When the rockshaft falls that rapidly after raising, typically, the gasket between the rockshaft lift cylinder and the rear cover is blown. It's not a complex job, but can be complicated if you have problems removing the piping, and hoisting the rear cover which can be pretty heavy and awkward.
Drain rear-end fluid (good time to flush and re-fill if needed. Flush with diesel fuel is a good thing. Remove the pressure and return piping from the Powr-Trol pump. DON'T DAMAGE THESE TUBES....THEY ARE NO LONGER AVAILABLE. Remove all the cap screws and lift the cover off.
While you have the cylinder off, install a new o-ring on the lift cylinder piston. Use a good shellac or permatex sealant on the rear cover gasket because you don't want it to leak. I like to use two pieces of threaded rod to use as guide pins when sliding the rear cover back into position.
If you don't have a manual, at least have your dealer print you out the page or two from the parts manual.
P.S. If you have ever noticed that the pto cluch housing get over full or looses oil, it can be because the pto has a gear pump in it for clutch lubrication, and a seal in it might have failed. It is very easy ro replace this seal while you have the rear cover off. FYI...
Hope this helps !
Frank-in-Tallahassee
70D // 855
Tye
05-01-2002 05:33:40
Hank, The power-trol on that 50 is pretty simple. It's not hard at all to take it apart and replace the gaskets.
