70 clutch need help
sam
04-30-2002 17:52:29
I have a 1956 model 70 and the clutch pulley is pitted badly on the inside where the disks fit. I have already bought every thing else is there any thing i can do other than buying a ney pulley.
Gman
05-01-2002 18:31:10
 Re: 70 clutch need help in reply to sam, 04-30-2002 17:52:29
Sam I wouldn't fret over a few fits back there,just clean up or wire brush the clutch surface and reassemble.Take note if you remove the cotter keys on adjusting bolts and pusk the in and out the litlle dogs on the back side fall out of there position,and there isn't enough room to get your hand between the dust sheild and pulley to replace them. You then have to press the gear off the sliding assembly and this takes a fifty ton press(been there done that)so be careful. Gman
60
05-01-2002 19:14:48
 Re: Re: 70 clutch need help in reply to Gman, 05-01-2002 18:31:10
Gman...I need to replace my drive disc in my 60 series, will I run into the same issue of pressing something apart???
