Any POWERSTROKE drivers out there?
Bill R
12-12-2003 07:03:44
Just getting my first powerstroke this weekend (pre-owned :) ) and just was curious how many other jd guys were driving them. I am a diehard Ford man and after having experience with them prior to purchasing this one I wouldn't have anything else. Thanks for your comments
Bill R
A // B // GW // R Diesel
Ben.So.Tex
12-13-2003 05:13:36
 Re: Any POWERSTROKE drivers out there? in reply to Bill R, 12-12-2003 07:03:44
I run vol EMS here in the county and we have 3 power stroke and they run fine out of a cold garage start up and run them 80+ mph and they have been holding up, can't wait for warm up when on a 911 call. Good luck Ben
tim
12-13-2003 04:33:01
Have owned both ford and dodge diesels, there really is no comparison.. That Cummins motor is incredible. Stay FAR AWAY from the powerstroke,your wallet will thank you..
Gary in TX
12-13-2003 08:18:33
 Re: Re: Any POWERSTROKE drivers out there? in reply to tim, 12-13-2003 04:33:01
Yea, come to think of it I have heard that the powerstrokes like fuel real well too and like to stroke your wallet dry.
Gary in TX
12-12-2003 21:54:28
I'm sorry, did you loose a bet?????
:o) Just funnin with ya but for myself I'll never own another Ford Product.
Denny Foster
12-12-2003 19:33:36
I am a diesel mechanic for a county government, nearly all of our light duty diesel trucks are powerstroke 7.3's. We have a few non turbo older 7.3s and a couple of the GM 6.5's. The most inherent problem with all of them is glow plug system failures, I have changed a many glow plugs timers, relays, modules, etc. The 7.3 Powerstroke is a very dependable machine however it has its drawbacks as all engines do, the injector harness tend to be troublesome under the valve covers and You don't want to buy a pump or injectors for one $$$$. The new 6.0 Powerstroke diesel is a whole new ball of wax with the timing gear drivetrain located in the rear flywheel area it is a doozy not to mention hardly any underhood room to work on them. We had a lot of trouble with the 12 units we bought earlier in the year with the turbo boost blowing the intercooler hoses off and with a rough rolling hot idle, Ford rectified the hose problem by "gluing" them in place and clamping them and the idle problem has been addressed with a PCM reprogram, only time will tell as far as durability. Myself as a diesel mechanic I said why beat em when you can join them!!! The OTR truckers have been using Cummins inlines for years and you guessed it, my diesel is a straight 6 Cummins no peskey glowplugs just a reliable intake heater grid 21 degrees this AM no block heater plugged in fired right up. Easy to work on and mostly inexpensive. Well That was all of my opinion. sorry so winded.
Denny
Denny Foster
12-12-2003 19:35:43
 Re: Re: Any POWERSTROKE drivers out there? in reply to Denny Foster, 12-12-2003 19:33:36
BTW I thought you guys were all green men, driving a truck with a red engine (IHC) whats up with that!!! HA HA HA HA
jdemaris
12-12-2003 19:23:29
Well, I'm not a Ford fan. I've got four G.M. trucks with 6.2 diesels and love them. My Suburban has 450,000 miles on it with no engine tear downs (everything else has been replaced at least once, some many times). That being said, I just bought a low mileage Ford F250, 8,600 GVRW with the International 6.9 diesel. Great running engine and I love the truck. I only bought it because I couldn't find a GM with an extended cab, 4WD, 3/4 ton, full 8' bed, and under 150K miles for under $7,000. Felt very bad about it at first because of those letters on the hood (i.e. FORD), but I've gotten over it and really like the truck. From all I've read, it's one of the most reliable diesel engines Ford used.
Bill R
12-12-2003 18:34:34
Yes i agree with all the mods tearing up the transmissions. This truck had no chip in it, and will have no modifications done to it while i have it either. Was just through a ford authorized shop with all new seals, gaskets, piston rings, injectors checked and associated things so I feel a lot better about buying it. Have a buddy that runs 3 powerstrokes and never had any problems he has a 99 SD powerstroke, original automatic transmission with 175,000 and still pulling strong, (his truck never goes anywhere without a 30+ ft flatbed goosneck, thats the only thing its used for.) Thanks for the opinions
Henry J
12-12-2003 15:52:01
Bill
Ain't it a little late to ask? I bought a 99 new and could tell you a whole bunch of things to put into the calculator to see how much money you wanted to pay for the big noise, cost of maintenance, and high priced diesel now a days.
As others have said, unless you have real deep pockets stay away form all those mods that cause flames to run down the exhaust pipe.
Mine dumped me on the side of the road three times in the first 15,000 miles. That and after being in the shop twice for a clanking #8 injector it has been bumping along pretty good up to 80,000 now.
It does pull the 11,000 # high profile camper fine as long as a huge head wind don't hit you. Over all it has averaged 10 mpg pulling the camper. That is 11.4 downwind and 9.2 upwind lol.
Good Luck and maybe I will hear you rattling through the campground in FL shortly.
charlie walesh
12-12-2003 13:52:24
I own a 1996 powerstroke diesel it's the best damn truck money can buy. Mine has 184,000 thousand miles on it and it's not even broken in yet. I drove a brand new duramax chevy and it was pooch compared to mine. It also has more power than my dad's dodge with a cummins. "PS: He's very jealous off me!"
mike
12-12-2003 12:04:03
I had a 97, it was a great running truck, and I loved the power and torque, but here is what I had trouble with mine, it ate tires and front brakes for lunch, the whole nine yards too, glow plug relays, almost had the thing burn down because the fuel cannister got a bad leak, the heater in the can shorted out, soaked my clutch up really nice, ford wouldnt fix with out a fight, even though they covered the fuel bowl, did finally say they would work with me on the clutch, if it ever failed, if buying the older style truck, make sure it has the serpentine belt upgrade and at least a new top idler pulley as it will definitely leave you on the side of the road, carry a spare cam position sensor, this will also strand you, if a 98 or older and a stick, check for more than 3/4" of flywheel rotation , if more, the dual mass is bad and will cost you around 2000 from ford, if let go , it will tear the tail shaft out of the tranny and that is 5000 from ford, not alot cheaper at a yard if you can find it, watch out for a truck with any chips especiall big ones and ones that are modified with out an exhaust temp guage, can tweak the turbo fins and that it 1200 bucks, I dont want to sound like a ford basher, but most of these problems listed are things I had actually happen, and if your truck doesnt make you money, you may want to consider somthing else, they are not cheap to fix, bottom line, good truck , had alot of trouble, now running a silverado, with alot less trouble, ps get a good warranty, even if you have to pay extra, it will be worth it, trust me.
Jack
12-12-2003 13:36:24
 Re: Re: Any POWERSTROKE drivers out there? in reply to mike, 12-12-2003 12:04:03
I heard that,I had a 97 6.5 Chevy and I took a beating on it but see ya later"BYE,BYE'you piece of S&!t,I traded for a 2000 Silverado with a gasser.Had it 5 months and 10000 miles later and NO PROBLEMS,I mean nuthin but oil changes and tire rotations.Turbo,injector pump,clutch-pressure plate,ecm,all very very expensive.Before I get another diesel I will have hit the lotto or inherited a mint,or suffered a massive brain damaging head trauma.I know of a 96 Ford F250 P/S that shorted out a relay UNDER the right valve cover and guess what,"$1500.00"bucks later it was repaired.Co workers Cummins left her on the side of the road and according to the dealer it was gonna cost 4000.00 bucks for an injection pump if not covered under warranty,luckily for her is was able to be squeezed in under factory warranty.If you get a good one than hallaluyah for you but if you get a dud than get ready to rob a bank or dig deep into the pockets.Good luck to whatever you decide and hope it works for you.
Bob-Wyo
12-12-2003 11:36:16
Bill, I bought a 96 crew cab Centurion Auto trans,last year, 82,000 miles and all the goodies, including TV, VCR, radar detector, theft recovery system, best seats I have ever had, etc. Only time it was out of the garage was to pull there fifth wheel trailer, looked like new.
Now then it will pull a D and R JD up the road at 75 MPH at elevation of 6500' and don't even strain, (NO CHIP) D IS 7450#, R IS 11,200# for a total of 18,650# on a duel tamdem trailer.
Chip will give lots of extra HP, BUT trans won't take it. Proven by a friend that spent 400.00 for a chip and then took out the trans 3 times in 3 trips hauling his drag car. Yep he is a lead foot too. Don't think any of them will take it, or the factory would have added the HP there
Just my 2 cents, as you can tell I LIKE IT, have owned many 1 tons of all makes.
Bob
Ray
12-12-2003 11:13:30
The 7.3 powerstroke is a good motor,the new engine has a lot of problems,ford has been
forced to buy back over 500 trucks (saw this in
a truck industry trade magazine).I've owned a
couple,no problems other than wheel seals.
I'm driving a Duramax now really like it,the
ford tranny just won't hold up towing.
Dave G (Ohio)
12-12-2003 08:27:59
I just bought a new Power Stroke 250. Love it... My brother has 7.3 with 198000 miles standard transmission - power chip & he loves it... The only thing I hear is the automatic transmissions are problemmatic. But I suspect the ones that are having problems may have a power chip. I ran across one that had problems and he did have the chip. Just my 2 cents worth.
