Jd 50 Power-Trol Pump
Tye
04-30-2002 08:01:29
I have reason to believe for a number of years the power-trol pump on my 50 was left turned on. The only problem was, was that the system didn't have any oil in it. Recently, I got the system to fuction correctly and so far it works fine. Should I be concerned with the condition of the pump because of all those years left turned on? Like I said the rockshaft works great. I appreciate any responses. Have a good one.
Clooney
04-30-2002 16:24:52
 Re: Jd 50 Power-Trol Pump in reply to Tye, 04-30-2002 08:01:29
Tye, if the pump was left turned on for years with no oil in it, you wouldn't have gotten it functioning. ~There might have been more oil in the system than you thought or is was turned off for most of the time.
~If it functions ok now it will probably be good to go for a long time..... .
G-MAN
04-30-2002 10:33:59
Tye, I am by no means a power-trol expert, but I would say that if it ain't broke, don't fix it. As long as everything appears to be okay and functions properly, I would leave it be. As long as the pump is not making excessive noise etc, you're probably alright. If you have problems in the future, tear into it then. Just my two cents.
Thank you Clooney and G-MAN
04-30-2002 19:51:05
 Re: Re: Jd 50 Power-Trol Pump in reply to G-MAN, 04-30-2002 10:33:59
Thank you very much Clooney and G-MAN for your comments. That makes me feel better that there might not be anything to worry about after all. Thanks again. -Tye Wintersteen, VA
