Auto Fuel Shut-Off dripping gas
50man
04-29-2002 19:19:32
I was cleaning my sediment bowl and put it back on my 50 (with oil press. shut-off) and didn't prime it right away. About half an hour later I noticed the bowl had some gas in the bottom of it and saw the inlet valve had a slow drip. My question is if my tractor sits a while, will the gas keep running into the carb and get into the base over time?
John T
04-30-2002 11:11:54
 Re: Auto Fuel Shut-Off dripping gas in reply to 50man, 04-29-2002 19:19:32
50 man, The answer is YES if that rubber gasket is leaky, gas will flow past it. However, even if it does, if the carbs needle valve and seat and float are working properly, the carb bowl would fill and then gas would not overflow. That small flat round rubber gasket you mention (which lets gas flow into the sediment bowl) is readily available and cheap to replace. Ol John T
auto shut replacement man
04-29-2002 19:28:33
John Deere has a kit bowl you can replace with...I did, I didn't want to worry about that thing..also, I know I need to put a carb kit in it..the float valves are leaky.....about $22.00 for the replacement...
