12 volt conversion
BW
04-29-2002 16:06:10
Anyone know of place that sells kits to go from 24V to 12V system for a 730 diesel?
G Taylor
04-29-2002 23:34:04
 Re: 12 volt conversion in reply to BW, 04-29-2002 16:06:10
Green* Magazine has reprints of the factory 12/24V service manual. The system works well if properly mantained. What is happening with your 730? If one battery is always found dead check for a short to chassis through the starter or generator. Extra lights or loads tinkered on without balancing the two 12V systems will certainly cause grief.
BW
04-30-2002 09:12:31
 Re: Re: 12 volt conversion in reply to G Taylor , 04-29-2002 23:34:04
actually its working ok right now, but i thought it would be simpler to change it over to make it easier to charge or jump start. maybe i should just leave well enough alone!
