51 A wheels
bob s ia
04-28-2002 06:32:19
i have a 1951 A and would like to move the rear wheels in but they wont move' removed the 3 bolt clamp and drove chisels in the 3 slots and pried pushed and hammered. thay will not move. dont want to use heat but may not have any outher way to go.
easydoesit
04-29-2002 12:38:19
 Re: 51 A wheels in reply to bob s ia, 04-28-2002 06:32:19
Do not drive wedges in the three slots while you try to move the wheel. They will thighten against the splines..... .Run allthread rods into the three hub boltholes and then put a heavy plate on the rods that you can put a 10 ton jack to the end of the axel and remove the wheel. If you want a better description come back. easy
ronald buser
04-28-2002 19:36:09
i have a 1940 A,and had the same problem.we ended up making a puller threaded rod and 1" plate to pull the hubs completely off of the splined shaft.first i soaked the axle with penetrating oil for a week.then made three bolts long enough to go through hubs and used plate like a gear puller to remove hubs. it helps to wire brush as much debris and rust from splines as possible, and spray penetrant or light oil on splines as you pull on the hub, but we did not have to heat anything. good luck!
Bob s ia
04-28-2002 14:52:13
dick i tryed the old ditch trick about six times. it didnot work. I mat have to try the trick that ralph did to his wheels. thanks guys ill soak them and do the ditch trick.
POPPER DICK
04-28-2002 13:33:45
Bob,
I had the same problem with my 50 "B" when I went to pick it up in Illinois when I bought it. I needed to move them in to get it on the trailer I was using to haul it home. I loosened the clamp and drove down a road with a ditch at the side in and out of the ditch putting side way pressure on the tire. After about six or seven times of in and out of the ditch it popped loose and began to move. Be careful not to shove it all the way off the spline doing this. You just have to be careful. I soaked it good with penetrating oil before doing this.
Dick
Ralph
04-28-2002 12:48:50
I have used a propane torch that didn't take the paint (old) off, followed by penetrating oil and it was enough to loosen things up. If you don't want to use heat, use penetrating oil (PB? Blaster), put you back into the tire and pound the tire with a hammer sufficiently heavy to cause some vibration. If you have the clamp (three bolt) loose you have won most of the battle.
