Another easy 40 Standard question
stacey
04-28-2002 03:53:39
I am waiting on my service manual (really). I drained both the final drives and tranmission. Is there a seperate fill hole for the final drives or just use the main fill hole on the right side.
Thanks, Stacey
Clooney
04-28-2002 05:34:05
 Re: Another easy 40 Standard question in reply to stacey, 04-28-2002 03:53:39
Stacey, The trans & final drives are separate & each fill with their own oil. [90 Weight gear oil]
~The final drive filler plug on a 40-S is on the inside of the final drive(s) just above the 3 point attachment brackets.
~The trans capacity is around 6.5 qts (actually to bottom of filler hole). ~Each final drive holds around 3.5 pints (again to bottom of filler hole).
stacey
04-28-2002 06:16:01
 Re: Re: Another easy 40 Standard question in reply to Clooney, 04-28-2002 05:34:05
Thanks, Clooney!
