Fuel filter for JD 435 JD Tractor W. Detroit Diesel
CJ
04-27-2002 19:20:29
I need to know where to find a fuel filter for a JD 435 tractor with Detroit Diesel. Is this available through JD, and if so what is the current part number?
Mark Scholten
04-28-2002 06:32:00
 Re: Fuel filter for JD 435 JD Tractor W. Detroit Diesel in reply to CJ, 04-27-2002 19:20:29
They are sock type filters. Primary and secondary. Replace all "O" rings. One on the base where the can fits. One on the bolt stem where it goes through the filter can. There is an adapter kit to change the filters over to spin ons. Still meets restoration police quidelines. Mark
GEMALO
04-28-2002 12:06:30
 Re: Re: Fuel filter for JD 435 JD Tractor W. Detroit Diesel in reply to Mark Scholten, 04-28-2002 06:32:00
MARK, WOULD YOU FURINSH THE INFO TO GET AN ADAPTER KIT TO CHANGE TO A SPIN ON FILTER. THANKS, GEMALO
Mark Scholten
04-29-2002 04:20:41
 Re: Re: Re: Fuel filter for JD 435 JD Tractor W. Detroit Diesel in reply to GEMALO, 04-28-2002 12:06:30
Fuel filter adapter kits for Detroit Diesel 53 series.
Most Detroit Diesel engines using a replaceable cartridge type fuel filter can be converted to a spin on fuel filter by the installation of the K3326 and K3327 kits.
The K3326 kit and P1146 filter will replace those AC filters taking the C1169 (AC T552)cartridges.
The complete AC filters are T67 and T74 respectively.The K3326 and P3594 will replace the AC T60 filter assembly. A 3/8" - 18 pt (female) reducer is required for this conversion.
The K3327 kit and P1147A filter will replace the AC filters taking the C1175PL (AC TP540X and TP512) cartridges. The complete AC filters are T65 and T59 respectively. The K3327 with P3595 will also replace the AC T58 filter assembly.This filter takes the C1173PL (AC TP509) cartridge. A 3/8" - 18 pt (male) x 1/4" - 18 pt (female) reducer is required for this conversion.
The chart shows the kits, filters and what they replace.
Kit: K3326 takes spin on P1146 which replaces the AC T67 or T74 filters or the AC T522 and AC T552 cartidge. The numbers in Fram will be C1169.
Also P3594 replaces AC T60 filter and AC T553 cartridge. The Fram number is C1174 or C1174PL.
Kit: K3327 takes spin on P1147A and replaces AC T59 and AC T65 filters and AC TP512 and AC TP540X cartridges. the Fram numbers are C1175PL. Also P3595 replaces AC T58 filter and AC TP509 cartridge. The Fram number is C1173PL.
I hope I didn't misspell anything and I also hope this is not too confusing. Any questions, email me. Mark
JD435
04-27-2002 21:27:46
CJ I get filters from NAPA parts store. There are two different filters used, take yours and match up.
