JD Heaven and a couple of questions .
Ford Man
04-26-2002 20:55:12
I went to a coworker's father's house to work on some deer feeders we are building . When I got there , I saw that he is really into Deeres ! He had at least a dozen or more Deeres ! A , B , D , G , LA , 40T , 60 , 70 and some great big 1950's diesel ( don't know the model ) that looked like a locomotive . Makes my 3 tractor collection look pitiful .
I have a couple of questions that I hope you guys can help me with on my 40-S .
1)I need to replace the friction disks on the 3 point touch control lever . How do you get the spring and lever assembly apart ?
2) My left brake works fine but the right does not work . The pedal will only move about a 1/2" and feels like it is going against a dead stop but I get no braking at all . Any suggestions this side of taking off the final drive ?
Please help guys !
I am new to the John Deere game and need all the help I can get !
Ford Man
Wayne in Tn.
04-27-2002 11:52:21
 Re: JD Heaven and a couple of questions . in reply to Ford Man , 04-26-2002 20:55:12
Thfe shaft that the spring is on has a snap ring under the collars on each end, these can be a pain to remove, but that is what you have to do to get it apart to replace the discs. As to the brakes, the final drive has to be pulled to get to the brake pads and mechanisim.
Ford Man
04-27-2002 18:19:46
 Re: Re: JD Heaven and a couple of questions . in reply to Wayne in Tn., 04-27-2002 11:52:21
Wayne,
Thanks for the information ! I will go look at the touch control lever in a few minutes . You confirmed my suspicions that I would have to pull the final drive .
I love my 40 and can't wait to put her back to work .
Thanks Again !
Ford Man
