Battries
arthur H.
04-26-2002 19:56:59
have a 1970 john deer 300 industrial tractor with loader commonly known as a 2020 it has 2 12v. battries connected in series for 24v. is this incorrect. had a friend whom said it should be 2 6v. battries for a 12v. system witch is correct.
can anyone help me on that. thank you.
david
04-26-2002 21:44:59
 Re: battries in reply to arthur H., 04-26-2002 19:56:59
Check the starter and the altenator. The voltage will be stamped on these.Most likely it will be 12 volts.
Matt Jones
04-26-2002 20:53:29
You can keep the two 12 volt batteries. All you have to do is hook the positive to positive on the batteries. This will keep it 12 volt but give it twice as much cranking volts.
