Help! Need Water Pump JD 50
Fred McIntire
04-26-2002 15:16:07
Help!
I need a water pump for a JD 50 tractor. Mine is leaking around the shaft. I'm afraid I'll burn the engine up like this.
Does anyone know where I can find one? Does anyone rebuild these? I'm located in Indianapolis, Indiana.
Thanks
Fred McIntire
04-27-2002 20:25:47
 Re: Help! Need Water Pump JD 50 in reply to Fred McIntire, 04-26-2002 15:16:07
Thanks guys! I got the rebuild kit at the John Deere dealer today. It was less than $50.00. It has everything in it, including a new shaft!
Mark
04-27-2002 09:02:42
Hy-Capacity in Humboldt Iowa has rebuilt ones in stock for around $50.00. Ph.# is 515-332-2125
Fred McIntire
04-26-2002 20:03:49
Thanks! I really appreciate the information. I'll give them a call first thing in the morning.
Again, Thanks.
gwh
04-26-2002 15:43:21
Parts are available thru john deere to rebuild the pump. It is not hard to do, but if you don't follow correct shop manual procedure(removal of the snap ring-there are two styles-one on the shank of the casting-the other hidden under the pulley) you will end up with a broken casting.
G-MAN
04-26-2002 15:35:26
Parts are available at your JD dealer -and I'm sure they can rebuild yours too - it's a pretty simple process.
