4010 diesel 12 volt starter conversion
B.R.
12-11-2003 18:06:18
what and where on part # needed
Whitefield
12-12-2003 08:08:52
 Re: 4010 diesel 12 volt starter conversion in reply to B.R., 12-11-2003 18:06:18
Just did this to my 4010 diesel last summer. Wise decision. I got the kit from deere, kit includes reman starter, alternator, battery cables, a bit of a wiring harness. I ended up buying 2 new 6 volt batteries & all new cables to wire in series. You can use your current 12v batteries and use the supplied cables to go parallel. THE Company has a conversion kit for around $400. The deere kit was around $600 w/o batteries. I wish I had found this kit before changing mine over. Good luck.
Rodney A Johnson
12-12-2003 07:29:45
AES in Racine MN sells a 12 volt conversion kit for 415USD that goes on 3010, 3020, 4010, or 4020. I put one on my '64 4020D this summer, and was best thing I ever did.
Comes with 12 volt starter, 12 volt alternator, some ground battery cables, and directions on how to install. Each wire is labeled, so was fairly easy to install. Took only a few hours.
I can't seem to find the address and phone number or I'd include that as well.
mike
12-11-2003 20:13:25
I have 12volt nipp starter for your tractor, call me 816-586-2841, take 200.00 for it
B.R.
12-11-2003 20:44:06
 Re: Re: 4010 diesel 12 volt starter conversion in reply to mike, 12-11-2003 20:13:25
thanks mike I'll tell my buddy what you have
jdemaris
12-11-2003 19:05:44
Not sure if I understand the question, but if you're changing from 24 volt split system to a 12 volt system,the following is what you'd need for a 3020 or 4020, I don't remember exactly how the 3010s were wired: you will a 12 volt starter, 12 volt charging system of some sort (alternator is the easiest), heavier battery cables, and a bit of rewiring to do. Half the original dashboard is 12 volt positive ground, and the other half if 12 volt negative ground.
B.R
12-11-2003 19:37:11
 Re: Re: 4010 diesel 12 volt starter conversion in reply to jdemaris, 12-11-2003 19:05:44
thanks that gets me closer what 12 volt starter will fit a 4010
jdemaris
12-11-2003 19:48:22
 Re: Re: Re: 4010 diesel 12 volt starter conversion in reply to B.R, 12-11-2003 19:37:11
Mid to late model 3020s had 12 volt systems and the starters will fit the 3010s. Don't know for sure what else will fit.
