JD 317 Question
David Sawyer
04-25-2002 04:34:31
I'm looking at a JD 317 that supposibly had a new engine put in it 1-2 years ago. I haven't seen it, I'm discussing this mower with the owner over e-mail. I want to make sure it has a series II KT 17QS engine in it. The engine serial number is 2231009716. I know that the Series II engines started with series # 24300. Is the series number the first part of the serial number, or a seperate number on the engine? If it's a seperate #, where is it?
JD 4000
04-25-2002 12:25:36
 Re: JD 317 Question in reply to David Sawyer, 04-25-2002 04:34:31
Dont Brother with the serial number....
Ask the Owner of the 317 see if engine HAS a Oil Filter.. IF it has a Oil Filter then it's a Fine engine. I have a 317 has new engine 5-6 years ago I buy new one with oil filter it last for good long time if you keep oil checked and cleaned.
if I see other 317 I would buy it.
Charlie
04-25-2002 05:41:05
I don't have my 317 anymore but as I remember the serial number was on the same tag as the series number but were on separate lines. I think it was kind of hard to see the entire tag without taking of the air cleaner. Hope this helps.
