JD 37' Unstyled A
Matt From IN
04-24-2002 18:11:23
I want to put lights on My 1937 A. Does anyone have a clue how? I know I need and Alt.
And is a Model 4b 2 bottom plow a good comanion for the above?
Jerry S
04-27-2002 10:35:54
 Re: JD 37' Unstyled A in reply to Matt From IN, 04-24-2002 18:11:23
The 2 bottom plow will be fine for that tractor. I think a B could even pull 2 12's. Lights are going to be quite a deal. There isn't a way to put the battery anywhere unless you build a battery carrier and bolt it on somewhere like the side of the frame or something. You can get an alternator to work for it but will need to fit some mounting brackets for it and make sure your fan shaft is equipped to handle the belt. No matter where the lights go, they will have to be cobbled on some way. You will have to think ahead on where all the wires will run so they don't get burnt or chewed up or stepped on etc.
Matt from IN
04-28-2002 08:46:14
 Re: Re: JD 37' Unstyled A in reply to Jerry S, 04-27-2002 10:35:54
So how exactly should I wire all that together? My tractor already has a pulley on the fan shaft. The orignal owner made a good light bar for it but I don't know how to hook the bat, alt, and lights all together to work. Will the bat be ok when the lights are not on. (No juice being pulled of the bat.)
