JD 50 not a pile of rust but has power problems
Brian
04-24-2002 16:06:25
My 53 50 has excellent power running mowers or on the baler but when I am pulling a load up any hill it will die and I have to shift it down. The last time I did this I was pulling a hay rack with 100 bales on it. Is there something wrong or am I overdoing it?
Mikey G
04-24-2002 18:59:33
 Re: JD 50 not a pile of rust but has power problems in reply to Brian, 04-24-2002 16:06:25
Checkl your float level it sounds like it may be low and your running out of fuel.
Mikey G
CLW
04-24-2002 18:31:50
Brian, If it is steep or a long hill it could be normal. They don't pull a lot in 6th gear. Do you have trouble starting from a dead stop with the same load?
CLW
Brian
04-25-2002 10:05:46
 Re: Re: JD 50 not a pile of rust but has power problems in reply to CLW, 04-24-2002 18:31:50
I don't have problems starting out itsjust when pulling up a long hill.
mike
04-25-2002 19:32:38
 Re: Re: Re: JD 50 not a pile of rust but has power problems in reply to Brian, 04-25-2002 10:05:46
This may be normal as I had a JD 50 that made 31 horsepower on the dyno but just didn't seem to hang in there like my model B's
Tye
04-24-2002 17:00:27
Check your distributor. I had the same problem on my 50 until I checked the distributor
