? for F.I.T Electrolisis?
farmuse
04-23-2002 11:13:25
What liquid material is used in the electrolisis bath. I have an old rubbermaid stock tank I want to turn into an electrolisis bath to try it.
F-I-T
04-23-2002 12:16:22
 Re: ? for F.I.T Electrolisis? in reply to farmuse, 04-23-2002 11:13:25
Farmuse:
The electrolyte is either Calcium Carbonate (Washing soda) or Sodium Hydroxide (Lye), your choice. I use lye because it strips the old oil, paint, and grease better, but it's more alkaline, or basic, and hence a little more harse on your skin.
Any plastic container should work. My thinking is to use a plastic stock tank for the next project, and use my engine hoist to support heavy parts like wheel centers in the tank. Even being able to dip half a part at a time should be a plus.
F-I-T
farmuse
04-23-2002 12:35:46
 Re: Re: ? for F.I.T Electrolisis? in reply to F-I-T, 04-23-2002 12:16:22
How much lye per gallon of water?
F-I-T
04-23-2002 12:44:39
 Re: Re: Re: ? for F.I.T Electrolisis? in reply to farmuse, 04-23-2002 12:35:46
Farmuse:
I use one tablespoon of lye or washing soda per gallon of water. It's not critical at all. If I have a part that is so big that it creates too high a current draw, I might thin the mix. If I have a part the is really caked in paint, I might boost it up.
F-I-T
farmsue
04-23-2002 13:04:20
 Re: Re: Re: Re: ? for F.I.T Electrolisis? in reply to F-I-T, 04-23-2002 12:44:39
What amp setting you recomend? two or six
F-I-T
04-23-2002 16:41:08
 Re: Re: Re: Re: Re: ? for F.I.T Electrolisis? in reply to farmsue, 04-23-2002 13:04:20
I use a 10 amp setting on my charger. The part will only draw what it can based on surface area of the electrode, surface area of the part, and the distance between the two.
I typically draw 4-8 amps depending on the situation.
F-I-T
